@alfageme please help me to win build client, puedes ayudarme?
Have you tried following the build instructions? ownCloud Documentation Overview
If so, what errors have you encountered?
I have done the process in SuSE using Docker and compile but the .exe has unmistake after settling
I did tests with the client of Nextcloud and generates the same error
Share the Build
Https://www.dropbox.com/s/3z8y5pc65qmoxpr/Nextcloud-2.3.2.1beta-setup.exe?dl=0
Hey @goshdark138 you have a step-by-step guide in this central thread: Error using docker to build the windows client - #5 by alfageme. Word of advice: try first to create a non-themed client to discard errors that may come from that direction.
Hope to be “de ayuda” ![]()
que distribución de linux he de usar suse, ubuntu ? esa opción también la intente y el problema persiste
You can use the docker-ownCloud-client-win32/Dockerfile at master · guruz/docker-ownCloud-client-win32 · GitHub as template for what you’ll need to install on OpenSUSE 42.1 in order to get the cross-compilation of the client to work out. You’re probably missing some of the libraries that appear there.
RUN zypper --non-interactive --gpg-auto-import-keys ar http://download.opensuse.org/repositories/windows:/mingw/openSUSE_42.1/windows:mingw.repo
