I’m trying to build the Desktop Client on windows but at the step craft owncloud-client it fails.
I am not experienced in Powershell so I don’t really know how to fix the errors
The paste is here https://gist.github.com/DMontey5/00a87e0f209607ca26b2901b075192c8
Did you follow instructions from the docs?
https://doc.owncloud.org/desktop/building.html#windows-development-build-with-kde-craft
The ownCloud team uses MSVC instead of mingw/gcc. Could you give it a try?
