not upload in file and not show upload, while me pull file in web notification "You don’t have permission to upload or create files here" , but can upload in gallery
i'm use ubuntu 16.04
php 7.0
nginx
owncloud 9.1.6
thanks for awnser !
file config nginx.
server {
server_name cloudnine.com;
access_log /var/log/nginx/your_domain-access.log;
error_log /var/log/nginx/your_domain-error.log;
root /var/www/html/owncloud;
location / {
index index.php;
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass unix:/run/php/php7.0-fpm.sock;
Hello,do you have checked the authorization for directories ?
i'm configure permission for www-data folder owncloud
You can be explain more than
please help me !
I think there is a reason why the documentation has an own section with a nginx configuration:
https://doc.owncloud.org/server/latest/admin_manual/installation/nginx_configuration.html
ok. thanks you . i will configure same as they
