Hi
I’ve installed owncloud from app center.
I’ve configured owncloud but after a while i could not access it.
I’ve uninstalled/reinstalled owncloud but i don’t get the configuration wizard - instead i get a user/password login request.
I’ve tried to use all the passwords/default passwords i could think of but i could not get access.
I’ve tried to reset password with " /mnt/ext/opt/apache/bin/php /share/Web/owncloud/occ user:resetpassword admin " command
but I got this result:
exception ‘Exception’ with message ‘Not installed’ in /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/lib/base.php:223
Stack trace:
#0 /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/lib/base.php(558): OC::checkInstalled()
#1 /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/lib/base.php(1039): OC::init()
#2 /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/console.php(12): require_once(‘/share/CACHEDEV…’)
#3 /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/occ(11): require_once(‘/share/CACHEDEV…’)
#4 {main}{“reqId”:“4ecead96f746af2423b666cc1383a1a3”,“remoteAddr”:“”,“app”:“PHP”,“message”:“touch(): Unable to create file /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/data/owncloud.log because No such file or directory at /share/CACHEDEV1_DATA/.qpkg/owncloud/owncloud/lib/private/log/owncloud.php#48”,“level”:3,“time”:“2016-08-27T17:05:14+00:00”}
my question is: how can i truly reset owncloud or how could i reset admin password even though the configuration wizard can not run?
thanks a lot.
Tamir
