Help restoring folders from trash bin
recently some folders were deleted form my owncloud server and I tried to restore them as descried below. Since I have no backup of these folders I would be grateful for any help I can get to restore them.
Not reproducible
Accidentally deleted folder should be restored from the trashbin with the webinterface
It was not possible to restore all folders. Received the Message “Couldn’t restore folder”.
Operating system: Ubuntu 16.04 LTS
Web server: Apache/2.4.18 (Ubuntu)
Database: QSL
PHP version: PHP 7.0.18-0ubuntu0.16.04.1
ownCloud version: ownCloud 9.1.6 (stable)
Where did you install ownCloud from: webpackage
  "system": {
        "updatechecker": false,
        "instanceid": "ockztzlln0e3",
        "trusted_domains": [
            "schiedung.ddnss.de",
            "192.168.0.40"
        "overwrite.cli.url": "https:\/\/schiedung.ddnss.de\/owncloud",
        "dbtype": "sqlite3",
        "version": "9.1.6.2",
        "logtimezone": "UTC",
        "installed": true,
        "maintenance": false,
        "theme": "",
        "loglevel": 0
  "system": {
            "192.168.0.40"
        "installed": true,
        "theme": "",
        "loglevel": 0
Are you using encryption: No
[Symfony\Component\Console\Exception\CommandNotFoundException]
Browser: Chrome Version 59.0.3071.86 (Offizieller Build) (64-Bit)
