This issue seems to be related to the Calendar app but I’m not sure about it.
It seems a random behavior so I really don’t know how to reproduce it
It should be possible to see or edit each calendar in the same way
Some user’s calendar it’s impossible to see (perennial spinning weel)
at least one user just have problem in setting up new events (it needs to reload the page at each step, starting from the click to open the editor)
if the calendar doesn’t load in the owner’s page it’s impossible to load it while shared with other users
imported in thunderbird it seems to work as expected
From Owncloud log it seems it’s a token validation matter:
{“reqId”:“ezvUiiVwnMZIw3tx6oGgGV”,“level”:0,“time”:“2024-01-19T08:24:53+00:00”,“remoteAddr”:“79.11.238.2”,“user”:“–”,“app”:“OC\Authentication\Token\DefaultTokenProvider::invalidateToken”,“method”:“REPORT”,“url”:“/remote.php/dav/calendars/USER-WORKING/personal_shared_by_USER-NONWORKINGCALt/”,“message”:“invalidating token a20a81b79450fa1cb1cf9ec7825fc464800aaa48c43985e8ae8e6dd84d342963b3af26b27be953ad90be6ae9fc3cb704451cbf39c68946dddd5550b7364bb2b8”}
Docker instance
Debian 12
Apache2 from the docker
Maria DB 10.11
PHP Version => 7.4.3-4ubuntu2.19
10.13.4 (stable) (problem showed up a few days before updating from 10.13.3)
updated several times in the years
Docker from owncloud
“system”: {
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/custom”,
“url”: “/custom”,
“writable”: true
“trusted_domains”: [
“own.bcelt.eu”
“datadirectory”: “/mnt/data/files”,
“dbtype”: “mysql”,
“dbhost”: “db”,
“dbname”: “owncloud”,
“dbtableprefix”: “oc_”,
“log_type”: “owncloud”,
“supportedDatabases”: [
“sqlite”,
“mysql”,
“pgsql”
“upgrade.disable-web”: true,
“default_language”: “en”,
“overwrite.cli.url”: “http://own.bcelt.eu/”,
“htaccess.RewriteBase”: “/”,
“logfile”: “/mnt/data/files/owncloud.log”,
“loglevel”: 3,
“memcache.local”: “\OC\Memcache\APCu”,
“mysql.utf8mb4”: true,
“filelocking.enabled”: true,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “redis”,
“port”: “6379”
“version”: “10.13.4.1”,
“logtimezone”: “UTC”,
“installed”: true,
“instanceid”: “ocr1pro6z08r”,
“mail_smtpmode”: “smtp”,
“mail_smtpsecure”: “tls”,
“mail_smtpauth”: 1,
“mail_smtpport”: “587”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“maintenance”: false,
“files_antivirus.av_cmd_options”: “”,
“files_antivirus.av_path”: “/usr/bin/clamscan”,
“allow_user_to_change_mail_address”: “”,
“debug”: false
**List of activated apps:**
Enabled:
- activity:
- Version: 2.7.2
- announcementcenter:
- Version: 1.2.2
- Path: /var/www/owncloud/apps/announcementcenter
- brute_force_protection:
- Version: 1.3.0
- Path: /var/www/owncloud/custom/brute_force_protection
- calendar:
- Version: 2.0.0
- Path: /var/www/owncloud/custom/calendar
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.2
- dav:
- Version: 0.7.0
- diagnostics:
- Version: 0.2.0
- Path: /var/www/owncloud/apps/diagnostics
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.6.0
- files_antivirus:
- Version: 1.2.2
- Path: /var/www/owncloud/apps/files_antivirus
- files_external:
- Version: 0.9.0
- files_pdfviewer:
- Version: 1.0.2
- Path: /var/www/owncloud/custom/files_pdfviewer
- files_sharing:
- Version: 0.14.0
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- impersonate:
- Version: 0.6.0
- Path: /var/www/owncloud/custom/impersonate
- market:
- Version: 0.8.0
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- tasks:
- Version: 0.9.7
- Path: /var/www/owncloud/custom/tasks
- templateeditor:
- Version: 0.5.0
- Path: /var/www/owncloud/custom/templateeditor
- updatenotification:
- Version: 0.2.1
Disabled:
- admin_audit:
- Path: /var/www/owncloud/apps/admin_audit
- customgroups:
- Path: /var/www/owncloud/apps/customgroups
- drawio:
- Path: /var/www/owncloud/apps/drawio
- encryption:
- enterprise_key:
- Path: /var/www/owncloud/apps/enterprise_key
- external:
- files_classifier:
- Path: /var/www/owncloud/apps/files_classifier
- files_external_dropbox:
- Path: /var/www/owncloud/apps/files_external_dropbox
- files_external_ftp:
- Path: /var/www/owncloud/apps/files_external_ftp
- files_ldap_home:
- Path: /var/www/owncloud/apps/files_ldap_home
- files_lifecycle:
- Path: /var/www/owncloud/apps/files_lifecycle
- files_mediaviewer:
- files_primary_s3:
- Path: /var/www/owncloud/apps/files_primary_s3
- files_texteditor:
- Path: /var/www/owncloud/apps/files_texteditor
- firewall:
- Path: /var/www/owncloud/apps/firewall
- firstrunwizard:
- graphapi:
- Path: /var/www/owncloud/apps/graphapi
- guests:
- Path: /var/www/owncloud/apps/guests
- kerberos:
- Path: /var/www/owncloud/apps/kerberos
- metrics:
- Path: /var/www/owncloud/apps/metrics
- notifications:
- oauth2:
- Path: /var/www/owncloud/apps/oauth2
- openidconnect:
- Path: /var/www/owncloud/apps/openidconnect
- password_policy:
- Path: /var/www/owncloud/apps/password_policy
- ransomware_protection:
- Path: /var/www/owncloud/apps/ransomware_protection
- sharepoint:
- Path: /var/www/owncloud/apps/sharepoint
- systemtags_management:
- Path: /var/www/owncloud/apps/systemtags_management
- theme-enterprise:
- Path: /var/www/owncloud/apps/theme-enterprise
- user_external:
- user_ldap:
- Path: /var/www/owncloud/apps/user_ldap
- user_shibboleth:
- Path: /var/www/owncloud/apps/user_shibboleth
- web:
- Path: /var/www/owncloud/apps/web
- windows_network_drive:
- Path: /var/www/owncloud/apps/windows_network_drive
- wopi:
- Path: /var/www/owncloud/apps/wopi
- workflow:
- Path: /var/www/owncloud/apps/workflow
NO
NO
NO
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
no errors on the webserver log
sanitized extract (tail -n “owncloud (3).log” | grep USER-NONWORKINGCAL | grep -i cal)
{"reqId":"a6vUmp1unDftv74Ho8BQ","level":0,"time":"2024-01-19T08:24:52+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::validateToken","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"token 04f8a97e95cfee636bda55a9cb69c455ad3a9364bb1d5c04c6acadf2da5f700c6f04ee5c4204d2396fa50d0e56ab96aed606c9b86e029300a4ff3ac078f244b7, not found"}
{"reqId":"a6vUmp1unDftv74Ho8BQ","level":0,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"core","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"OC\\Authentication\\LoginPolicies\\GroupLoginPolicy policy registered"}
{"reqId":"a6vUmp1unDftv74Ho8BQ","level":1,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::loginInOwnCloud","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"login USER-WORKING using \"password\" login type"}
{"reqId":"ezvUiiVMZIw3tx6oGgGV","level":0,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\Authentication\\Token\\DefaultTokenProvider::invalidateToken","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"invalidating token a20a81b79450fa1cb1cf9ec7825fc464800aaa48c43985e8ae8e6dd84d342963b3af26b27be953ad90be6ae9fc3cb704451cbf39c68946dddd5550b7364bb2b8"}
{"reqId":"ezvUiiVMZIw3tx6oGgGV","level":0,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::login","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"regenerating session id for uid USER-WORKING, password set"}
{"reqId":"ezvUiiVMZIw3tx6oGgGV","level":0,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::validateToken","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"token 04f8a97e95cfee636bda55a9cb69c455ad3a9364bb1d5c04c6acadf2da5f700c6f04ee5c4204d2396fa50d0e56ab96aed606c9b86e029300a4ff3ac078f244b7, not found"}
{"reqId":"ezvUiiVMZIw3tx6oGgGV","level":0,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"core","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"OC\\Authentication\\LoginPolicies\\GroupLoginPolicy policy registered"}
{"reqId":"ezvUiiVMZIw3tx6oGgGV","level":1,"time":"2024-01-19T08:24:53+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::loginInOwnCloud","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"login USER-WORKING using \"password\" login type"}
{"reqId":"RoiFoIpr3dXDXkQCDBfs","level":0,"time":"2024-01-19T08:27:07+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\Authentication\\Token\\DefaultTokenProvider::invalidateToken","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"invalidating token a286e8cb6855df9370f309d2cc67d1ceb409258bb2452875dc8df5c32ba33467f5ee1109710391dae765ebe4b86e954983a6b577e9416c277eac85dc71c90803"}
{"reqId":"RoiFoIpr3dXDXkQCDBfs","level":0,"time":"2024-01-19T08:27:07+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::login","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"regenerating session id for uid USER-WORKING, password set"}
{"reqId":"RoiFoIpr3dXDXkQCDBfs","level":0,"time":"2024-01-19T08:27:07+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::validateToken","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"token 04f8a97e95cfee636bda55a9cb69c455ad3a9364bb1d5c04c6acadf2da5f700c6f04ee5c4204d2396fa50d0e56ab96aed606c9b86e029300a4ff3ac078f244b7, not found"}
{"reqId":"RoiFoIpr3dXDXkQCDBfs","level":0,"time":"2024-01-19T08:27:07+00:00","remoteAddr":"79.11.238.2","user":"--","app":"core","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"OC\\Authentication\\LoginPolicies\\GroupLoginPolicy policy registered"}
{"reqId":"RoiFoIpr3dXDXkQCDBfs","level":1,"time":"2024-01-19T08:27:07+00:00","remoteAddr":"79.11.238.2","user":"--","app":"OC\\User\\Session::loginInOwnCloud","method":"REPORT","url":"\/remote.php\/dav\/calendars\/USER-WORKING\/personal_shared_by_USER-NONWORKINGCALt\/","message":"login USER-WORKING using \"password\" login type"}
{"reqId":"l3RcsdzxiUv54aOoAhE1","level":0,"time":"2024-01-19T08:29:10+00:00","remoteAddr":"2.34.29.192","user":"USER-NONWORKINGCALt","app":"OC\\User\\Session::validateToken","method":"GET","url":"\/apps\/calendar\/","message":"token 48fa6f25537324906904a9d369582bb18bd69c2903aa4efb111b241a85f2f22dc9ee2b614b2e081f056d7a19a2b3e954dad238fabf0060e7c82022484e9dedd3 with token id 112725 found, validating"}
{"reqId":"FMk2jQpIWaob1Q6X6US9","level":0,"time":"2024-01-19T08:29:10+00:00","remoteAddr":"2.34.29.192","user":"USER-NONWORKINGCALt","app":"OC\\User\\Session::validateToken","method":"POST","url":"\/index.php\/apps\/calendar\/v1\/config","message":"token 48fa6f25537324906904a9d369582bb18bd69c2903aa4efb111b241a85f2f22dc9ee2b614b2e081f056d7a19a2b3e954dad238fabf0060e7c82022484e9dedd3 with token id 112725 found, validating"}
{"reqId":"9xTZpMzUOnPFWlm7Jba7","level":0,"time":"2024-01-19T08:29:11+00:00","remoteAddr":"2.34.29.192","user":"USER-NONWORKINGCALt","app":"OC\\User\\Session::validateToken","method":"PROPFIND","url":"\/remote.php\/dav\/calendars\/USER-NONWORKINGCALt\/","message":"token 48fa6f25537324906904a9d369582bb18bd69c2903aa4efb111b241a85f2f22dc9ee2b614b2e081f056d7a19a2b3e954dad238fabf0060e7c82022484e9dedd3 with token id 112725 found, validating"}
{"reqId":"RwcJktG61fgZrCIEVUPe","level":0,"time":"2024-01-19T08:29:11+00:00","remoteAddr":"2.34.29.192","use
#### Browser log
jquery-migrate.min.js?v=54bdeeb1f7369df6ecd85782981a67c4:2 JQMIGRATE: Migrate is installed, version 1.4.0
moment-with-locales.js?v=54bdeeb1f7369df6ecd85782981a67c4:281 Deprecation warning: use moment.updateLocale(localeName, config) to change an existing locale. moment.defineLocale(localeName, config) should only be used for creating a new locale See Moment.js | Guides for more info.
warn @ moment-with-locales.js?v=54bdeeb1f7369df6ecd85782981a67c4:281
deprecateSimple @ moment-with-locales.js?v=54bdeeb1f7369df6ecd85782981a67c4:333
defineLocale @ moment-with-locales.js?v=54bdeeb1f7369df6ecd85782981a67c4:2141
i.m.a @ vendor.js:39927
i @ vendor.js:39927
i @ vendor.js:39927
i.m.a @ vendor.js:39932
i @ vendor.js:39927
(anonymous) @ vendor.js:39927
hslToRgb @ vendor.js:39927
vendor.js:27213 Attempting to call a FullCalendar method on an element with no calendar.
a.warn @ vendor.js:27213
(anonymous) @ vendor.js:39250
each @ jquery.js:374
each @ jquery.js:139
u.fn.fullCalendar @ vendor.js:39224
viewRender @ app.js:461
S.publiclyTrigger @ vendor.js:35936
h.publiclyTrigger @ vendor.js:35456
f.triggerViewRender @ vendor.js:30070
e @ vendor.js:28020
d @ jquery.js:4855
dispatch @ jquery.js:4435
r.handle @ jquery.js:4121
trigger @ jquery.js:4350
a.event.trigger @ jquery-migrate.min.js?v=54bdeeb1f7369df6ecd85782981a67c4:2
triggerHandler @ jquery.js:4907
u.trigger @ vendor.js:28001
a.runRemaining @ vendor.js:35116
a.tryStart @ vendor.js:35116
a.resume @ vendor.js:35116
f.stopBatchRender @ vendor.js:29965
S.renderView @ vendor.js:36176
S.initialRender @ vendor.js:36089
S.render @ vendor.js:35996
(anonymous) @ vendor.js:39258
link @ app.js:2440
(anonymous) @ vendor.js:633
(anonymous) @ vendor.js:5676
ue @ vendor.js:5696
B @ vendor.js:5132
(anonymous) @ vendor.js:4388
B @ vendor.js:5127
(anonymous) @ vendor.js:915
$eval @ vendor.js:10457
$apply @ vendor.js:10472
(anonymous) @ vendor.js:913
invoke @ vendor.js:2710
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
(anonymous) @ vendor.js:16195
j @ jquery.js:3099
fireWith @ jquery.js:3211
ready @ jquery.js:3417
I @ jquery.js:3433
viewRender @ app.js:475
e @ vendor.js:28020
d @ jquery.js:4855
link @ app.js:2440
ue @ vendor.js:5696
B @ vendor.js:5132
B @ vendor.js:5127
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
client.js?v=54bdeeb1f7369df6ecd85782981a67c4:252 XHR finished loading: PROPFIND “https://own.bcelt.eu/remote.php/dav”.
request @ client.js?v=54bdeeb1f7369df6ecd85782981a67c4:252
propFind @ client.js?v=54bdeeb1f7369df6ecd85782981a67c4:92
(anonymous) @ app.js:5511
(anonymous) @ app.js:5499
instantiate @ vendor.js:2710
(anonymous) @ vendor.js:2636
h.$get @ vendor.js:2628
(anonymous) @ vendor.js:2573
u @ vendor.js:2710
a @ vendor.js:2710
ye.instance @ vendor.js:1055
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
vendor.js:6754 XHR finished loading: GET “https://own.bcelt.eu/custom/calendar/templates/colorpicker.html”.
(anonymous) @ vendor.js:6754
(anonymous) @ vendor.js:6554
(anonymous) @ vendor.js:6620
(anonymous) @ vendor.js:9722
(anonymous) @ vendor.js:9738
$digest @ vendor.js:10334
$apply @ vendor.js:10488
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
vendor.js:6754 XHR finished loading: POST “https://own.bcelt.eu/index.php/apps/calendar/v1/config”.
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
client.js?v=54bdeeb1f7369df6ecd85782981a67c4:252 XHR finished loading: PROPFIND “https://own.bcelt.eu/remote.php/dav/principals/users/anna.bennett/”.
(anonymous) @ app.js:5526
Promise.then (async)
u @ vendor.js:2710
a @ vendor.js:2710
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
client.js?v=54bdeeb1f7369df6ecd85782981a67c4:252 XHR finished loading: PROPFIND “https://own.bcelt.eu/remote.php/dav/calendars/anna.bennett/”.
(anonymous) @ app.js:5584
getAll @ app.js:5577
(anonymous) @ app.js:323
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
client.js?v=54bdeeb1f7369df6ecd85782981a67c4:252 XHR finished loading: REPORT “https://own.bcelt.eu/remote.php/dav/calendars/anna.bennett/personal/”.
getAll @ app.js:6497
l.fcEventSource.events @ app.js:2902
(anonymous) @ vendor.js:34752
construct @ vendor.js:28611
l.fetch @ vendor.js:34751
d.requestSource @ vendor.js:34108
f.addSource @ vendor.js:34326
S.addEventSource @ vendor.js:36656
(anonymous) @ vendor.js:39244
R @ app.js:212
(anonymous) @ app.js:279
(anonymous) @ app.js:276
(anonymous) @ vendor.js:10282
$digest @ vendor.js:10359
(anonymous) @ app.js:326
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
client.js?v=54bdeeb1f7369df6ecd85782981a67c4:252 XHR finished loading: REPORT “https://own.bcelt.eu/remote.php/dav/calendars/anna.bennett/personal_shared_by_francesca.rinaldi/”.
R @ app.js:212
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
app.js:4291 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘hasProperty’)
at app.js:4291:18
(anonymous) @ app.js:4291
(anonymous) @ app.js:4274
E.p.getFcEvent @ app.js:4249
(anonymous) @ app.js:2912
(anonymous) @ app.js:2911
l.fcEventSource.events @ app.js:2903
R @ app.js:212
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
at app.js:4291:18
R @ app.js:212
B @ vendor.js:5071
t @ vendor.js:911
ne @ vendor.js:919
te @ vendor.js:794
j @ jquery.js:3099
I @ jquery.js:3433
c) …
