Thanks for the response!
This is my 1st time of actually opening a new topic in this medium and wasn’t aware that i had to fill out the template.
Also i have checked the log files and below are few of the output:
{“reqId”:“Z67f7TfJENihCS78IQT8”,“remoteAddr”:“207.45.172.134”,“app”:“public”,“message”:“Exception: {"Exception":"Error","Message":"Class ‘OCA\\Files_Sharing\\Connector\\PublicAuth’ not found","Code":0,"Trace":"#0 \/mnt\/clouddata\/owncloud\/public.php(74): require_once()\n#1 {main}","File":"\/mnt\/clouddata\/owncloud\/apps\/files_sharing\/publicwebdav.php","Line":34}”,“level”:3,“time”:“2016-11-04T20:33:08+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“98XfrosJZ9VWK0zG6DTw”,“remoteAddr”:“207.45.172.134”,“app”:“public”,“message”:“Exception: {"Exception":"Error","Message":"Class ‘OCA\\Files_Sharing\\Connector\\PublicAuth’ not found","Code":0,"Trace":"#0 \/mnt\/clouddata\/owncloud\/public.php(74): require_once()\n#1 {main}","File":"\/mnt\/clouddata\/owncloud\/apps\/files_sharing\/publicwebdav.php","Line":34}”,“level”:3,“time”:“2016-11-04T20:33:20+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“7PmIghCQWlRCysZ5NFnI”,“remoteAddr”:“207.45.172.134”,“app”:“public”,“message”:“Exception: {"Exception":"Error","Message":"Class ‘OCA\\Files_Sharing\\Connector\\PublicAuth’ not found","Code":0,"Trace":"#0 \/mnt\/clouddata\/owncloud\/public.php(74): require_once()\n#1 {main}","File":"\/mnt\/clouddata\/owncloud\/apps\/files_sharing\/publicwebdav.php","Line":34}”,“level”:3,“time”:“2016-11-04T20:33:22+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“eNfL6vPp+nrXYsfikwTG”,“remoteAddr”:“207.45.172.134”,“app”:“public”,“message”:“Exception: {"Exception":"Error","Message":"Class ‘OCA\\Files_Sharing\\Connector\\PublicAuth’ not found","Code":0,"Trace":"#0 \/mnt\/clouddata\/owncloud\/public.php(74): require_once()\n#1 {main}","File":"\/mnt\/clouddata\/owncloud\/apps\/files_sharing\/publicwebdav.php","Line":34}”,“level”:3,“time”:“2016-11-04T20:33:25+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
{“reqId”:“TsyNUizgVNu8Zan2f6BT”,“remoteAddr”:“207.45.172.134”,“app”:“public”,“message”:“Exception: {"Exception":"Error","Message":"Class ‘OCA\\Files_Sharing\\Connector\\PublicAuth’ not found","Code":0,"Trace":"#0 \/mnt\/clouddata\/owncloud\/public.php(74): require_once()\n#1 {main}","File":"\/mnt\/clouddata\/owncloud\/apps\/files_sharing\/publicwebdav.php","Line":34}”,“level”:3,“time”:“2016-11-04T20:33:32+00:00”,“method”:“PROPFIND”,“url”:“/public.php/webdav/”,“user”:“–”}
