High memory utilization - 9.1.1 on Centos
  1. Reboot Owncloud server once or twice a day
  2. Memory utilization is normal to start with
  3. After a few hours mysqld is using a huge amount of memory
Memory utilization should remain normal - no reboots necessary
Daily reboot required.
OS: Centos 7
Web server: Nginx
Database: Mysql / Mariadb
PHP version: 2.4.0
ownCloud version (see ownCloud admin page): 9.1.1 stable
Integrity status for oC9+
paste the results here.
ps aux --sort=-%mem | awk ‘NR<=10{print $0}’
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
mysql 14112 6.4 2.3 1761684 189996 ? Sl 07:25 1:41 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
This is a virtual server and I have tried increasing memory from 8gb to 16 gb but the issue still occurs.
issues like that should be always reported directly to GitHub · Where software is built
Thanks.
