Hi all,
I am running OC 10 on Debian through the OC repositories.
I moved my data directory following the documentation.
Now I am getting messages in my owncloud.log:
{"[...] "user":"--","app":"no app in context","method":"PROPFIND","url":"\/remote.php\/webdav\/","message":"User backend OC\\User\\Database is returning home: \/srv\/www\/oc_data\/\/myuser for user: myuser which differs from existing value: \/srv\/www\/oc_data\/myuser"}
So in the first path there is a double slash after data while the second path only has a single slash. Should no matter to Linux but OC seems to get confused.
I followed the steps in the above documentation to update the values in the MariaDB and updated the table “oc_storages” with the current value without the leading slash.
Whatever I do, once OC runs for a while I have a second entry in the table with the leading slash.
What did I do exactly?
- Stop OC and Apache:
systemctl stop apache2 - Login to MariaDB:
mysql -u root -p owncloud:
MariaDB [owncloud]> select * from oc_storages;
| id | numeric_id | available | last_checked |
| home::root | 1 | 1 | NULL |
| home::myuser | 3 | 1 | NULL |
| local::/srv/www/oc_data | 20 | 1 | NULL |
| local::/srv/www/oc_data/ | 21 | 1 | NULL |
Entry with numeric_id 21 was created by OC.
3. Delete other entry and update the one from OC:
MariaDB [owncloud]> delete from oc_storages where id='local::/srv/www/oc_data';
Query OK, 1 row affected (0.007 sec)
MariaDB [owncloud]> update oc_storages set id='local::/srv/www/oc_data' where id='local::/srv/www/oc_data/';
Query OK, 1 row affected (0.003 sec)
Rows matched: 1 Changed: 1 Warnings: 0
- Check again:
| home::cvoelker | 3 | 1 | NULL |
| local::/srv/www/oc_data | 21 | 1 | NULL |
13 rows in set (0.001 sec)
So all apears to be fine.
5. Double check in table oc_accounts:
MariaDB [owncloud]> select * from oc_accounts;
| id | email | user_id | lower_user_id | display_name | quota | last_login | backend | home | state |
| 1 | myuser@oc-domain.de | myuser | myuser | Name Surname | none | 1619549048 | OC\User\Database | /srv/www/oc_data/myuser | 1 |
10 rows in set (0.000 sec)
Looks good, doesn’t it?
5. exit from MariaDB and restart Apache2:
systemctl start apache2
Very quickly I am getting again these messages.
Checking the oc_storages table I have a new entry now:
| local::/srv/www/oc_data | 22 | 1 | NULL |
| local::/srv/www/oc_data/ | 23 | 1 | NULL |
WITH the leading slash…
Anyone having an idea what is wrong here?
THANKS a lot!
/KNEBB
