Hook don´t fire
Hey @everybody,
I am a newcomer and have a litte problem with my own app. I want to fire a hook, that add a LDAP user to his LDAP shared group folder. This is what I want at the end. For the first testing I only want that the hook create a log-file when I create an user in the backend. But it didn´t work and I didn´t get any errors. I created the hook as desribet in the development manual:
And this is the code that I had created:
AppInfo/app.php
<?php
namespace OCA\LdapFolder\AppInfo;
$app = new Application();
$app->getContainer()->query('LdapHooks')->register();
//\OCP\Util::connectHook('OC_User', 'post_createUser', 'OCA\LdapFolder\Hooks\LdapHooks', 'LdapHooks');
lib/AppInfo/Application.php
<?php
use \OCP\AppFramework\App;
use \OCA\LdapFolder\Hooks\LdapHooks;
class Application extends App {
	public function __construct(array $urlParams=array()){
		parent::__construct('ldapfolder', $urlParams);
		$container = $this->getContainer();
		 * Controllers
		$container->registerService('LdapHooks', function($c) {
			return new LdapHooks(
				$c->query('ServerContainer')->getUserManager()
lib/Hooks/LdapHooks.php
<?php
namespace OCA\LdapFolder\Hooks;
class LdapHooks {
	private $userManager;
	public function __construct($userManager){
		$this->userManager = $userManager;
	public function register() {
		$callback = function($user) {
			$file=fopen("test.txt", "a");
			fwrite($file, 'it is working' . $user);
			fclose($file);
		$this->userManager->listen('\OC\User', 'postCreateUser', $callback);
I hope that I made only a little mistake, or that I understand something wronge.
Thank you for your help
Best Regards
Hey there,
I have a similar problem, using ownCloud 10.
Anyone any idea on how to do it right?
For reference: Topic „Filesystem hooks don’t fire“
