Want to integrate owncloud into my webpage. How can I do that? Tried to include it using iframe, but still didn’t get any expected result. Can someone please help me with this asap?
maybe some of the existing threads on this topic is helping you to achieve what you’re looking for?
It is in this time not possible to embed collabora office in the learning management system MOODLE. Alternative I intend to embed owncloud-10-docker with collabora-docker plugin in moodle. Moodle has a plugin for owncloud fileaccess. Owncloud is in my domain, but moodle in a other. So X-Frame-Options: SAMEORIGIN prevent embedding. X-Frame-Options: ALLOW-FROM https://moodle.cc/ ignored in .htaccess. I think SAMEORIGIN is hardcoded. What can I do in this case?
Issue - I want to embed in a iframe an owncloud folder. - Even changing the option X-Frame-Options in the htaccess file, doesn't solve the problem, keeps giving me an x-Frame-Options Sameorigin error.
Expected behaviour After changing the option Header set X-Frame-Options to "ALLOW-FROM http://display-website.de/ ", still not "allowing" this domain, or not making any change at all.
Actual behaviour I can't see the iframe in http://display-website.de/ , throws me an error: Refused to display 'h…
