I installed onto my QNAP OwnCloud 8.1
I downloaded from the Play Store OwnCloud 3.0.4
I went through the Admin setup on the QNAP and am looking at the file list.
On the mobile app it is asking for the server address. I have tried:
http : // 10.0.0.11
10.0.0.11:8080
http : / / 10.0.0.11/owncloud/index.php/apps/files
and every other combination I can think of. NONE OF THEM SHOW A USERNAME OR PASSWORD LINE.
Most of the time, I get a “Failed to connect to server”, but I have seen other errors as well.
From the phone in a browser, http :// 10.0.0.11 takes me straight to the QNAP login.
Any advice for a 1st time user?
LinkP
May 5, 2023, 1:29pm
2
You may want to start with figuring out how to install a newer version of ownCloud on your QNAP.
OwnCloud 8.1 has been unsupported for over six years.
" Operating System
The ownCloud app works on QNAP NAS devices running QTS version 4.5.4 and higher."
Unfortunately I’m stuck on 4.2.6
i don’t think that any recent versions of the ownCloud clients (Android, iOS, Windows/Linux) are still compatible with such heavily outdated ownCloud versions.
You can download older versions of the Android on F-Droid or *.APK‘s from the releases on GitHub.com that should work with older ownCloud version. Search feature here is your friend.
system
Closed
August 15, 2023, 6:50am
7
