Hello! I am trying to run a different server on my Raspberry Pi, and I would like to temporarily disable OwnCloud. I can’t figure out how to “turn it off”. I do not want to uninstall it because I want to run OwnCloud soon and I have lots of information on it.
oC is just a web application so it won’t take any resources if you don’t access it. So it don’t need to be disabled.
If you want to avoid that others are accessing the installation you can put it into maintenance mode:
Or stop the apache/ nginx.
Ask the server administrator where you have an account and ask them to delete it?
