How do I increase owncloud upload speed?
  1. Installed owncloud via docker portainer on pi 5
  2. Uploaded a test file via local IP
  3. Uploaded a test file via public IP
Speed should be at least 5mbps
Speed when uploading via local IP is around 20mbps (which is good). However, speed when accessing remotely is sub 1mbps!
Raspberry Pi OS bookworm
Apache
MariaDB
Owncloud x?
Fresh
Docker portainer
No SSL (http access)
<?php
$CONFIG = array (
  'instanceid' => 'xxxxxxxxxxxxx',
  'passwordsalt' => 'xxxxxxxxxxxxxx',
  'secret' => 'xxxxxxxxxxxxx',
  'trusted_domains' =>
  array (
    0 => 'xxx.xxx.xxx.xxx:8080',
    1 => 'xxx.xxx.xxx.xxx:8080',
  'datadirectory' => '/var/www/html/data',
  'overwrite.cli.url' => 'http://xxx.xxx.xxx.xxx:8080',
  'dbtype' => 'mysql',
  'version' => '10.0.10.4',
  'dbname' => 'owncloud',
  'dbhost' => 'db',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'owncloud_rw',
  'dbpassword' => 'xxxxxxx',
  'logtimezone' => 'UTC',
  'installed' => true,
  'files_external_allow_create_new_local' => 'true',
yes - local
Are you using encryption:
no
Google Chrome
Windows 11
i think if the upload speed via local IP is acceptable then i think the bottle neck is not ownCloud and i think you need to look into other components like the router, the network equipment or similar.
