Hello!
I’m using Owncloud old 2018 Docker image and it’s working very well. But since it’s deprecated i’m trying to build a new Owncloud server using the owncloud/server docker image.
Problem is : the image doesn’t work on aarch64 (arm64v8)
So i’ve git pull everything and started to build from scratch, but the owncloud/php docker image pull a repository from https://download.owncloud.com/download/repositories/sernet/samba-4.8/ubuntu/ which contain only i386 and amd64 packages.
I mostly use Centos and Archlinux so i’m quite a noob in .deb packaging but i’m wondering how do you compile and build those packages? Do you have a CI/CD where i could get how you do it?
Thank you for your help
