Hello.
I like to benchmark my OwnCloud installation. Is there any ‘standard’ benchmarks available to test the OwnCloud performance?
Hello.
i did the following search https://www.google.com/search?q=“owncloud”+“benchmark” and found:
Some other resources are also pointing towards:
Hi. Thanks for suggestions. I finally used the apache benchmark tool.
not sure if the apache benchmark tool is a good choice as this probably only testing the apache web server and not PHP and ownCloud which adds another layer of software to your web server.
