1.My hosting provider has broken something on the server side, as a result of which no one can login via the web client (OC server and desktop clients work fine)
2. Hosting sysadmin is asking me for OC admin pwd to troubleshoot. I cannot give that out as it is re-used else where
3. I would like to change the admin pwd to something generic, before giving out to hosting sysadmin. The problem is I can't change it since I cannot login to web app.
Operating system: Linux
Web server: Apache
PHP version: 5.4 (this is reported by CPANEL - I cannot check the OC admin page to confirm this)
ownCloud version (see ownCloud admin page): 9.1.4 (info from CPANEL only)
Updated from an older ownCloud or fresh install: no updates
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): none
Unable to access the log since unable to login
Integrity status for oC9+
Unable to access the status since unable to login
Is there a way to change the admin password directly in MySQL or from a console? OC server is running fine.
Or could I run a copy of the login page from another source than my OC server, pointing to the active server to apply the normal PWD change routine? I know the current admin pwd, it is not lost or wrong.
This is not the purpose of my request, but in case it helps, the Chrome Page Inspector reports 2 x errors on the login page as follows (it was fine until the hosting provider broke something yesterday):
login:1 Error parsing header X-XSS-Protection: 1; mode=block, 1; mode=block: expected semicolon at character position 14. The default protections will be applied.
login:12 Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'self' 'unsafe-eval'". Either the 'unsafe-inline' keyword, a hash ('sha256-HASH REPLACED BY ME IN CASE IT IS SENSITIVE'), or a nonce ('nonce-...') is required to enable inline execution.
=> As far as I'm concerned it's for the box syadmin to revert what ever change they have made on the back end...quickly!
Thanks in advance
