How to change the footer color
How do I change the color of the footer in OC 8.2? I tried to change the colors of
#body-public footer .info {
color: #777;
text-align: center;
margin: 0 auto;
padding: 20px 0;
#body-public footer .info a {
color: #777;
font-weight: 600;
padding: 13px;
but it doesn’t worked.
Can you send a Live Website with 8.2 so that I can show you the needed CSS?
For what do you need a live Website? Just post the code to change here and the name of the file, if it’s not styles.css.
@Liwindo Hi, maybe this url can help you:
Thx but no, 'cause there’s no word about the footer-color.
@Liwindo did you set ‘theme’ => ‘example’ in your config.php?
Steps i did and went fine:
  1. Edit themes/example/core/css/styles.css with your code
  2. Edit config.php file with this line:
Open my browser and the colour was changed
That’s my code of the styles.css of my template and the footer don’t work:
#body-login {
text-align: center;
background-image: url(‘…/img/background.jpg?v=1’);
background-position: 50% 50%;
background-repeat: no-repeat;
background-size: cover;
color: #000000;
text-align: center;
margin: 0 auto;
padding: 20px 0;
color: #000000;
font-weight: 600;
padding: 13px;
margin: -13px;
