I have installed owncloud now two weeks ago, and told the app to sync my pictures to the server.
Well… that never happened. I’ve since figured out that when I click send in the gallery I can get owncloud to upload it. So that worked for emergencies to get a picture in my computer-network, but it is not how it was intended to work.
Now today I decided to give it another try, mainly to try and figure out what mis-configuration I’d done to prevent the uploads from working. Browsing around I accidentally got it to upload one image to the root of my cloud. Not my intention, but I triggered that.
Then a few moments later, suddenly the camera sync seemed to be running.
The sync should work, or something should explain why it isn’t working. (can’t reach server?)
I don’t know.
Can this problem be reproduced with the official owncloud server?
I don’t know.
Environment data
Android version: miui global 11.0.4
Device model: redmi 6
Stock or customized system: stock.
ownCloud app version: beats me. downloaded jul 26 or 27.
ownCloud server version: Beats me. Downloaded less than a week earlier.
