I am using OCIS 7.1, is it possible to query storage space by users with either WebGUI or CLI?
@alex-lt-kong not possible through the UI as far as I know. But can be done via simple curl for example. Just query personal spaces and check the “quota” field. It contains a “used” field showing the used bytes. Note: This requires an admin user.
curl 'https://localhost:9200/graph/v1beta1/drives?%24orderby=name+asc&%24filter=driveType+eq+personal' -H 'Authorization: Bearer <token>'
Hi @robert88 the OCIS version I am using is:
Infinite Scale 7.1.4 Community
ownCloud Web UI 11.3.6
I dont have “Admin Panel → Users → Storage Usage“, are you sure it is made available already?
Hi @robert88 , I am using ocis-7.1.4-linux-amd64. When I run:
./ocis-7.1.4-linux-amd64 accounts list
the response I can see is:
No help topic for ‘accounts’
@alex-lt-kong Please take the responses of that user with a grain of salt as everything indicates that this is an AI powered spambot:
