Hello, I’m trying to setup OwnCloud to use an Amazon S3 bucket as external storage following the instructions from the website, but it keeps showing as red.
- Go to Admin Settings
- Go to Storage
- Select Amazon S3, put the name of the bucket, access key and secret
Show green as connected to the bucket.
Shows red as if it’s not connecting to it
Operating system: Ubuntu 18.04
Web server: Apache 2.4
Database: MySQL 5.7
PHP version: 7.2
ownCloud version: 10.1.1
Updated from an older ownCloud or fresh install: Fresh Install
Where did you install ownCloud from: owncloud repo from download site
Signing status (ownCloud 9.0 and above): N/A
