How to disable auto create folder
Hello all, we have ownCloud 9.1.4 (stable) it’s base at Ubuntu.
Server have only 100Gb HDD. Any work folder mapped via SMB.
Question is, how to disable automatically create folder “documents, photo” for new user.
Thank you!
Delete the contents of “core/skeleton/”
But that causes the integrity check to show a warning or am i wrong? At least the documentation [1] is saying that the skeletondirectory config.php options should be added with an empty value to get this behavior disabled.
[1] ownCloud Documentation Overview
Its work fine, thanks you!
Another question…how to deny create any file, folder, etc in main user folder.
Because if i make only read permission at folder /data, cloud don’t have access to create “user profile”
Thanks!
Please create new threads (also in the correct category) for each questions.
