I did the admin auto update from 9 to 10 and now OwnCloud doesn’t work as it says it requires PHP5.6 but I only have PHP 5.5.9
Please can a check be added BEFORE it attempts to upgrade, (for those future poor souls unfortunate enough to encounter this) but more importantly, can someone explain how I can downgrade back to the 9.* version? (I have full access to the server to add/remove files but no I can’t upgrade PHP)
As said, downgrading isn’t officially supported. Nevertheless, taking into account that the upgrade was aborted and it didn’t execute anything (as far as it seems), you might be able to restore the previous version.
If you can’t rollback to the previous version, you could either replace the all the code from 10 to 9, or install the same 9 version in another place. Keep in mind that the config and data folder in ownCloud MUST be the same, so don’t delete those folders.
Let me remark again:
This is NOT supported
This might break your installation, so be prepared in advance
Be careful and know what you’re doing before attempting to do something risky
The only reason you MIGHT pull it off is because no upgrade routine should have been executed yet
