This is probably a dumb question, but I can’t find anything on it anywhere, so I guess I’ll ask…
I just got OC 10 up and synced from an older OC (8.2) installation. I had copies of everything on my local directory, so I just sync’ed it all to the new OC folders. I had some older “conflict” files from the older OC in my local directories.
Now that I have resynced, I have about 500+ conflicts listed in my client “not synced” list. I can click on each entry and either delete the conflict file or rename it locally and that clears that one up. The question is if there’s an easier way than checking all 500+ files.
Many thanks!
