Trying to edit quotas for roles following this guide: Proxy Service Configuration
I know the names of the roles but cannot find their ids?
Do I have to extend the default proxy.yaml to add the role_quotas field?
If you use the default ocis roles, those are hardcoded here: ocis/services/settings/pkg/store/defaults/defaults.go at master · owncloud/ocis · GitHub
If you use custom roles, you can define your own ids for these. Though a uuid is recommended.
Yes. Just add the code snippet from the example
Ok, I extended and added the proxy.yaml to /etc/ocis but now the server won’t start unless I remove it:
policy_selector:
static:
policy: ocis
role_quotas:
2aadd357-682c-406b-8874-293091995fdd: 10737418240
policies:
- name: ocis
routes:
# defaults, taken from https://owncloud.dev/services/proxy/configuration/
- endpoint: /
backend: http://localhost:9100
- endpoint: /.well-known/
backend: http://localhost:9130
- endpoint: /konnect/
- endpoint: /signin/
- endpoint: /archiver
backend: http://localhost:9140
- type: regex
endpoint: /ocs/v[12].php/cloud/user/signing-key
backend: http://localhost:9110
- endpoint: /ocs/
- type: query
endpoint: /remote.php/?preview=1
backend: http://localhost:9115
- method: REPORT
endpoint: /remote.php/dav/
- type: query
endpoint: /dav/?preview=1
- type: query
endpoint: /webdav/?preview=1
- endpoint: /remote.php/
service: com.owncloud.web.ocdav
- endpoint: /dav/
- endpoint: /webdav/
- endpoint: /status.php
- endpoint: /index.php/
- endpoint: /apps/
- endpoint: /data
- endpoint: /app/
- endpoint: /graph/
backend: http://localhost:9120
- endpoint: /api/v0/settings
backend: http://localhost:9190
On oCIS 6.2
My docker.yaml running on port 9200, but changing the prefix didn’t work either.
services:
ocis:
image: owncloud/ocis-rolling:6.2.0
container_name: ocis_runtime
ports:
- "9200:9200"
volumes:
Mmh. That works for me.
What is the error message you get when you start the server?
Does is start without the role_quotas
block?
Do you need to reconfigure the routes? If not you can just leave that block out.
EDIT: I checked and I have problems when using your routes (with login mainly). Maybe just try without the policies
block?
docker starts fine, but when I go to my ocis public url I get a “This page isn’t working” 401 error, nothing in the /logs directory.
These are the rest of my envs:
OCIS_INSECURE: "false"
PROXY_ENABLE_BASIC_AUTH: "false"
PROXY_HTTP_ADDR: "0.0.0.0:9200"
WEB_UI_THEME_SERVER: "https://test.com"
WEB_UI_THEME_PATH: "/ocis/theme/theme.json"
WEB_ASSET_CORE_PATH: "/dist"
WEB_UI_CONFIG_FILE: "/config/config.json"
WEB_OIDC_CLIENT_ID: "web"
OCIS_URL: "https://storage.test.com"
PROXY_AUTOPROVISION_ACCOUNTS: "true"
PROXY_ROLE_ASSIGNMENT_DRIVER: "oidc"
OCIS_OIDC_ISSUER: "https://test.com"
PROXY_OIDC_REWRITE_WELLKNOWN: "true"
PROXY_USER_OIDC_CLAIM: "preferred_username"
PROXY_USER_CS3_CLAIM: "username"
PROXY_OIDC_SKIP_USER_INFO: "true"
OCIS_ADMIN_USER_ID: ""
OCIS_EXCLUDE_RUN_SERVICES: "idp"
GRAPH_ASSIGN_DEFAULT_USER_ROLE: "false"
GRAPH_USERNAME_MATCH: "none"
PROXY_CSP_CONFIG_FILE_LOCATION: "/etc/ocis/csp.yaml"
Yes it works now without the policies block:
policy_selector:
static:
policy: ocis
role_quotas:
Also, might want to add the capacity to the web UI (ej, X B out of Y used):
Isn’t that the case? It works for me:
Nope, on Web 10.0.0 and OCIS rolling 6.2.0, what version is that?
Mmh. Strange. I tried older version (6.1 ocis/9.2 web). But this is supposed to work. with actual version. I wonder why it doesn’t…
I did a fresh install without previous data and the percentages are now shown on client.
