How to import many user accounts at the same time
Hi, all:
I just installed the owncloud and I need to import the user accounts into the owncloud.
However, I found there is no way to import amount of user accounts in the same time in the web portal. Is that any possible way to do this? Now I have a XML file to store all the user accouts. The version of owncloud is 10.0.2.
Thank you.
Can anyone help me this?
Cause I have got a huge number of users, I can not create them once a time.
Thank you.
Recommend to use LDAP and import there. Alternatively you can use the provisioning API and write a script which does the provisioning for you.
Thank you for your reply.
The API seems not support importing many users at the same time.
How to use LDAP to import? I am a fresh in computer. Can you guide me how to do it?
Thank you.
Pure scripting approach:
export OC_PASS=initial_pass_alice
./occ user:add alice --display-name='Alice Cooper' --email='alice@cooper.net' --group=music --password-from-env
export OC_PASS=initial_pass_bob
./occ user:add bob --display-name='Bobby Brown' --email='bob@brown.net' --group=music --password-from-env
Thank you for your reply and sorry for my late reply.
I am not sure that I understand your idea.(Sorry for my fresh in computer). Is that meaning I still need to type all usernames password email group in script? That is a long list…Maybe I misunderstand your suggestions.
Maybe this code helps you to import a bulk of users from csv file to owncloud database.
First, you may have all the users data in a CSV file separated by commas with this columns: username_1,display name,password,email,group
Like this example:
valar.ainur,Javier Camacho,1234abcd,valar.ainur@email.com,users
Then, connect to your server via terminal and run this bash script in your owncloud home directory, in my case is: /srv/www/htdocs/owncloud
#!/bin/bash
input = "import_users_from_file.csv"
var_apache_user = www-data
var_path_owncloud = /srv/www/htdocs/owncloud
while read -r line
do
echo "Line: ${line}"
var_username = $(echo "${line}" | cut -d "," -f1)
var_name = $(echo "${line}" | cut -d "," -f2)
var_password = $(echo "${line}" | cut -d "," -f3)
var_email = $(echo "${line}" | cut -d "," -f4)
var_group = $(echo "${line}" | cut -d "," -f5)
set -e
export OC_PASS = $var_password
su -s /bin/sh ${var_apache_user} -c "php ${var_path_owncloud}/occ user:add --display-name='${var_name}' --group='${var_group}' --password-from-env --email='${var_email}' -- '${var_username}'"
done < "$input"
exit 0
