How to increase maximum upload size?
Hi. I’m using OwnCloud 8.2.7 on a shared server. I’m trying to increase the maximum upload size from 8 MB to 20 MB in the Admin page. The new size seems to be accepted when I click Save but when I reload the page it reverts back to 8 MB, and bigger file uploads get rejected.
My server PHP 5.6 configuration shows “upload_max_filesize = 32M”, my OwnCloud .htaccess shows “php_value upload_max_filesize 20M”, my OwnCloud .user.ini shows “upload_max_filesize=20M”, and I have loads of file space.
Can anybody suggest what I need to do here? Thanks for any help.
there are various other settings required depending on your environment / webserver. All needed and known information are collected here:
Hmm, I see my PHP post_max_size is 8M, which would explain it. Thanks.
