Hi
I would like to know if it’s possible to run 2 instance of owntcloud… like version 10 and 9 or a : 1 owncloud and 1 nextcloud. But on the same server with nginx and letsencrpyt.
So far the only tuto i found that work for just a simple install is : https://thelinuxcode.com/install-owncloud-centos-7/
But not sure if this can be done… as i got issues with the certbot also.
Thanks.
