Yes, so basically every time I click on the log out button on ownCloud Web, I get redirected back to its home page. Is there some setting on config.json that’s causing this? How can I log out from Web without going back to Classic (or just log out completely from Web)?
config.php:
"system": {
"trusted_domains": {
"0": "localhost",
"2": "coursepage.com",
"1": "storage.coursepage.com"
"web.baseUrl": "https:\/\/storage.coursepage.com\/index.php\/apps\/web",
"web.rewriteLinks": true,
"defaultapp" => "web",
"overwrite.cli.url": "http:\/\/localhost",
"dbtype": "mysql",
"version": "10.10.0.3",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"allow_user_to_change_mail_address": "",
"logtimezone": "UTC",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/apps-external",
"writable": true
"installed": true,
"instanceid": "oc9bcwsjao6d",
"filelocking.enabled": true,
"memcache.local": "\\OC\\Memcache\\Redis",
"redis": {
"host": "127.0.0.1",
"port": "6379"
config.json:
"server" : "https://storage.coursepage.com",
"theme": "https://storage.coursepage.com/themes/owncloud/theme.json",
"auth": {
"clientId": "T78skHLLdxEwJzJlyvaryWLy9ayk5g2bmJbn4GeFw5EyHCJPvRaUlMW90xah2YIx",
"url": "https://storage.coursepage.com/index.php/apps/oauth2/api/v1/token",
"authUrl": "https://storage.coursepage.com/index.php/apps/oauth2/authorize"
"apps" : [
"files",
"preview",
"draw-io"
"applications" : [
"title": {
"en": "Classic Design",
"de": "Klassisches Design",
"fr": "Design classique",
"zh_CN": "文件"
"icon": "swap-box",
"url": "https://storage.coursepage.com/index.php/apps/files"
"icon": "settings-4",
"menu": "user",
"target": "_self",
"title": {
"de": "Einstellungen",
"en": "Settings"
"url": "https://storage.coursepage.com/index.php/settings/personal"
