How to perform maintenance tasks
  1. Install oCIS as Systemd Setup ( https ://owncloud.dev/ocis/deployment/systemd/ )
  2. Try to run ocis commands
During upgrade from oCIS 3.0.0 to 4.0.0 i need to run “ocis migrate rebuild-jsoncs3-indexes”
I thought i run this command either as root or user ocis and the indexes are rebuilt
I cannot run it.
if i run as root (# ocis migrate rebuild-jsoncs3-indexes) i get “The jwt_secret has not been set properly in your config for sharing. Make sure your /root/.ocis/config config contains the proper values (e.g. by running ocis init or setting it manually in the config/corresponding environment variable).”
As i cannot login as user ocis i tried sudo (# sudo -u ocis /usr/local/bin/ocis migrate rebuild-jsoncs3-indexes) and got "The jwt_secret has not been set properly in your config for sharing. Make sure your /home/ocis/.ocis/config config contains the proper values (e.g. by running ocis init or setting it manually in the config/corresponding environment variable). "
i tried to setup the environment variables using “export” or just by definig them (f.e. OCIS_CONFIG_DIR=“/etc/ocis”
and get
"# echo $OCIS_CONFIG_DIR /etc/ocis " so it look fine.
Even if i run basic ocis commands, it always tells me no service found, also i can see in htop, that my service is running.
systemctl status ocis
● ocis.service - OCIS server
Loaded: loaded (/etc/systemd/system/ocis.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2023-09-05 07:23:16 CEST; 14h ago
Main PID: 538796 (ocis)
Tasks: 19 (limit: 9259)
Memory: 2.1G
CPU: 8min 45.909s
CGroup: /system.slice/ocis.service
└─538796 /usr/local/bin/ocis server
ocis version
Version: 4.0.0
Compiled: 2023-08-25 00:00:00 +0000 UTC
No running services found.
Thanks for any help!
Kind regards
Marc
Operating system: Debian 11
Web server: nginx
Database: n/a
PHP version: n/a
ownCloud version: oCIS 4.0.0
Where did you install ownCloud from: official download portal
What service are you talking about. This is different from the error message you posted before. What is the error message when you run with OCIS_CONFIG_DIR set?
first of all, thank you for your reply!
i configured the variable now, but still cannot perform the task :wink: please see below what happens
root@debian-8gb-fsn1-1 ~ # export OCIS_CONFIG_DIR=“/etc/ocis”
root@debian-8gb-fsn1-1 ~ # echo $OCIS_CONFIG_DIR
/etc/ocis
root@debian-8gb-fsn1-1 ~ # ocis migrate rebuild-jsoncs3-indexes
com.owncloud.api.storage-system: service not found
root@debian-8gb-fsn1-1 ~ # systemctl status ocis.service
Active: active (running) since Sun 2023-09-10 21:24:13 CEST; 15h ago
Main PID: 724553 (ocis)
Tasks: 24 (limit: 9259)
Memory: 673.7M
CPU: 3min 27.305s
└─724553 /usr/local/bin/ocis server
Sep 11 12:51:56 debian-8gb-fsn1-1 ocis[724553]: {“level”:“warn”,“service”:“storage-system”,“pkg”:“rhttp”,“traceid”:“00000000000000000000000000000000”,“host”:“127.0.0.1”,“method”:“GET”,“uri”:“/data/spaces/jsoncs3-share-m>Sep 11 12:52:21 debian-8gb-fsn1-1 ocis[724553]: {“level”:“error”,“service”:“proxy”,“error”:“failed to verify access token: token is expired by 1.063607246s”,“authenticator”:“oidc”,“path”:”/graph/v1.0/me/drives",“time”:">Sep 11 12:52:21 debian-8gb-fsn1-1 ocis[724553]: {“level”:“error”,“service”:“gateway”,“pkg”:“rgrpc”,“traceid”:“00000000000000000000000000000000”,“error”:“internal error: gateway: error finding an auth provider for type: >Sep 11 12:52:21 debian-8gb-fsn1-1 ocis[724553]: {“level”:“error”,“service”:“gateway”,“pkg”:“rgrpc”,“traceid”:“00000000000000000000000000000000”,“error”:“internal error: gateway: error finding an auth provider for type: >Sep 11 12:52:21 debian-8gb-fsn1-1 ocis[724553]: {“level”:“warn”,“service”:“frontend”,“pkg”:“rhttp”,“traceid”:“00000000000000000000000000000000”,“time”:“2023-09-11T12:52:21.442988288+02:00”,“message”:“core access token n>Sep 11 12:52:21 debian-8gb-fsn1-1 ocis[724553]: {“level”:“error”,“service”:“gateway”,“pkg”:“rgrpc”,“traceid”:“00000000000000000000000000000000”,“error”:“internal error: gateway: error finding an auth provider for type: >Sep 11 12:52:25 debian-8gb-fsn1-1 ocis[724553]: {“level”:“warn”,“service”:“storage-system”,“pkg”:“rhttp”,“traceid”:“00000000000000000000000000000000”,“host”:“127.0.0.1”,“method”:“GET”,“uri”:”/data/spaces/jsoncs3-share-m>Sep 11 12:52:26 debian-8gb-fsn1-1 ocis[724553]: {“level”:“warn”,“service”:“storage-system”,“pkg”:“rhttp”,“traceid”:“00000000000000000000000000000000”,“host”:“127.0.0.1”,“method”:“GET”,“uri”:”/data/spaces/jsoncs3-share-m>Sep 11 12:52:56 debian-8gb-fsn1-1 ocis[724553]: {“level”:“warn”,“service”:“storage-system”,“pkg”:“rhttp”,“traceid”:“00000000000000000000000000000000”,“host”:“127.0.0.1”,“method”:“GET”,“uri”:”/data/spaces/jsoncs3-share-m>Sep 11 12:53:05 debian-8gb-fsn1-1 ocis[724553]: {“level”:“warn”,“service”:“storage-system”,“pkg”:“rhttp”,“traceid”:“00000000000000000000000000000000”,“host”:“127.0.0.1”,“method”:“GET”,“uri”:”/data/spaces/jsoncs3-share-m>
Ah I see. Did you follow the ocis upgrade guide? Upgrading from 3.0.0 to 4.0.0
If you don’t have any shares on your system you can ignore the error message.
Yes did follow each step, therefore i ran this command :wink:
I think i don’t have any share yet, maybe that’s the whole problem <.<
Thanks for your help, then i will ignore the error in my journactrl
Have a nice evening!
Cool. If you have no shares you have no problem :slight_smile: Just one more question: Did you run ocis with OCIS_RUN_SERVICES="gateway,nats,storage-system,storage-users" during the update?
no, i did not start limited services.
instead i chose path B and disabled nginx for the upgrade process.
After journalctrl showed everything went smoothly and “ocis migrate decomposedfs -r list” gave me success for all users i started nginx again :wink:
