I’m on a quest to run OCIS on my homelab which consists a couple Intel NUCs running Proxmox, having a common CEPH with RBD and CephFS and a standalone NAS runnig OpenMediaVault.
I specifically do not want to run kubernetes. NUCs are just not enough powerful for that. Also I use it at work heavily so I know well how hard it is to maintain.
So far I managed to run every service in Docker Standalone or Swarm. Where it is possible/makes sense to run more then one replica of a service I do so easily.
But I hit a wall with OCIS.
I tried to decypher the helm-chart provided https://github.com/owncloud/ocis-charts/tree/main/charts/ocis but its just too complicated.
So far I figured that in order to run an OCIS cluster I would need a couple ‘common’ service to serve all the instances at once. Somehow I have to keep certain things in sync between nodes.
I already configured Nats as a cache store for couple things(I had earlier attemps with Redis aswell), and outsourced IDP to Authelia. Quite a journey on its own.
But still, my two instance of OCIS acts as separate things:
I’m authenticated in one, but after a browser refresh suddenly I’m not.
I upload a file that after a couple clicks in the GUI I cannot access anymore even tho the file is there… and all sorts of weird things.
I realize I’m still missing something, probably a lot of things.
My setup so far:
version: "3.9"
services:
nodes:
image: owncloud/ocis:7.0
hostname: ocis-{{.Task.Slot}}
ports:
- 9200:9200
networks:
- bana_global
entrypoint:
- /bin/sh
command: ["-c", "if [ \"$OCIS_REPLICA\" = \"1\" ]; then ocis init || true; fi; ocis server"]
environment:
TZ: "Europe/Budapest"
PUID: "1000"
PGID: "1000"
DEMO_USERS: "false"
OCIS_INSECURE: "true"
PROXY_TLS: "false"
PROXY_HTTP_ADDR: 0.0.0.0:9200
OCIS_URL: "https://ocis.my.domain/"
OCIS_LOG_LEVEL: debug
OCIS_LOG_COLOR: "true"
OCIS_LOG_PRETTY: "true"
STORAGE_USERS_OCIS_ROOT: /ocisdata
STORAGE_USERS_ID_CACHE_STORE: "nats-js-kv"
STORAGE_USERS_ID_CACHE_STORE_NODES: "nats:9233"
OCIS_REPLICA: "{{.Task.Slot}}"
OCIS_OIDC_ISSUER: "https://authelia.my.domain"
WEB_OIDC_CLIENT_ID: ownCloud-web
PROXY_OIDC_REWRITE_WELLKNOWN: "true"
PROXY_OIDC_ACCESS_TOKEN_VERIFY_METHOD: none
volumes:
- user-data:/ocisdata
- ocis-data:/var/lib/ocis
configs:
- source: ocis-config
target: /etc/ocis/ocis.yaml
deploy:
mode: replicated
replicas: 1
placement:
max_replicas_per_node: 1
nats:
image: nats
hostname: nats-1
command: [
"--jetstream",
"--store_dir", "/data",
"--port", "9233",
"--cluster_name", "NATS",
"--http_port", "8222",
"--server_name", "nats-1"
volumes:
- nats_data-1:/data
networks:
- bana_global
deploy:
mode: replicated
replicas: 1
placement:
configs:
ocis-config:
file: ./ocis.yaml
networks:
bana_global:
external: true
volumes:
user-data:
driver_opts:
type: "nfs"
o: "addr=LOCALIP,rw,hard,nfsvers=4.2"
device: ":/share/ocisdata"
ocis-data:
driver: local
driver_opts:
type: ''
o: bind
device: /data3/ocis
nats_data-1:
driver: local
driver_opts:
type: ''
o: bind
device: /data3/nats_data-1
Storage backend is twofold. User data is on my NAS(OpenMediaVault) via NFS 4.2
I tried really hard to make PosixFS work, but failed. That worth a topic on its own later ![]()
So currently ‘ocis’ storage driver is in use.
System data and Nats is on CephFS mounted (/data3) to my VMs.
Its published via Nginx on my own domain, secured with Certbot
server {
listen 80;
listen [::]:80;
server_name ocis.my.domain;
resolver 127.0.0.11 valid=10s;
resolver_timeout 5s;
location / {
return 301 http://$server_name$request_uri;
server {
listen 443 ssl proxy_protocol;
listen [::]:443 ssl proxy_protocol;
http2 on;
resolver 127.0.0.11 valid=30s;
resolver_timeout 30s;
ssl_certificate /etc/letsencrypt/live/my.domain/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/my.domain/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
location / {
set $upstream_ocis http://ocis_nodes:9200;
proxy_pass $upstream_ocis;
proxy_set_header Host $http_host;
proxy_hide_header Content-Security-Policy;
Loadbalancing is done by the Docker’s network. It works for any other service.
What do I miss? How do I make 2 or more OCIS instances to work together?
There are all sort of ‘CACHE’ enviroment variables. Do I need to set all to Nats? Or just some?
In the documentation, a lot of variables are marked ‘pre 5.0’ so its hard to figure what do I need and what I dont.
