I needed to reinstall Owncloud manual but when you put back the data from the users it does not update the DB. ( HINT HINT ) Maybe one day Owncloud can do that by itself like my Google Drive or One Drive. Take a picture with my phone, that picture automatically gets uploaded and I don’t have to do anything. I’m running
CentOS on a VPS with the user account trying to figure out the syntax of the OCC command to scan all the files. Any suggestions?
