Hello.
How to properly setup OCIS to work with HTTPS reverse proxy?
Hello.
Hi Alexander,
The docs for the small scale deployment show example NGINX and Apache reverse proxy configurations
Is that what you are looking for?
Otherwise if you are using the container images, have you looked into the following?
Let us know if you are looking for something else.
