How to Use occ on Command Line to Disable Two-Factor Authentication and Get Logged In
  1. Enable two-factor authentication and can’t set it up in admin area because of email issue
  2. Log out and attempt to log back in
  3. Receiving request for two-factor authentication that I forgot to disable but is not set up
I thought I should be able to log back in and bypass two-factor authentication since Admin account isn’t set up for it.
I enter Admin and password and get the two-factor authentication screen and have to cancel login.
Operating system: Centos 7.2
Web server: Apache
PHP version: 5.6
Updated from an older ownCloud or fresh install: Fresh Install
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): Two-Factor Authentication
Please paste possible errors in the following code block, see How to find webserver or OC logfile / enable php logfile for more info (Can’t log in to see these errors)
Integrity status for oC9+
paste the results here. (Can't log in to see these errors
Hi Yksityinen.
Try running via occ twofactorauth:disable
e.g.
sudo -u www-data ./occ twofactorauth:disable
If that command does not solve your problem, do not hesitate to write back here again.
Cheers,
David
The easy way is to uninstall it from your owncloud.
If you can’t login to admin account. you can find the verify code from the oc_twofactor_backup_codes table in your owncloud database then you can login to admin account to uninstall it.
I came here from How to Use Two-Factor Authentication With the ownCloud Desktop Client or Mobile Apps - ownCloud
I just had this problem with the Duo 2FA app as it no longer works with Duo’s new prompt.
occ app:disable duo
That disabled the app and allowed me to log back in without 2FA
Your reply to this five year old topic should probably be its own post, as it is likely to be quite relevant unless an update is made to the Duo application for ownCloud, something for which I have no expectations of seeing happen.
