How to use owncloud shell integration in my own app
Hello Everyone
I am developing a backup application with Rad Studio 11 C++
same as owncloud
with this application I want to show the backup processes to the user with iconoverlay
same as owncloud does
OCOK
OCSync
OCWarning
OCError
client-master\shell_integration\windows\OCUtil
I added the files in my project
I added a button and Edit
I wrote these codes to the button’s Click event
but
Edit1->Text = “C:\Dosyalar\01.txt”;
String Mesaj = L"RETRIEVE_FILE_STATUS: “+Edit1->Text+” \n",
Mesaj2 = L"STATUS::<“+Edit1->Text+”>\n";
CommunicationSocket *baglan = new CommunicationSocket();
std::wstring PipeAd = baglan->DefaultPipePath();
bool baglanti_durum = baglan->Connect(PipeAd);
if(baglanti_durum)
bool GeriDonus = baglan->SendMsg(Mesaj2.w_str());
Memo1->Lines->Add(“Mesaj2 Durum :”+BoolToStr(GeriDonus));
SHChangeNotify(SHCNE_UPDATEITEM, SHCNF_PATH | SHCNF_FLUSHNOWAIT, Edit1->Text.w_str(), nullptr);
Memo1->Lines->Add(“Ok”);
C:\Files\01.txt File’s Icon Iconoverlay process does not work
where is the error
thank you very much
