Hello ownCloud community,
I have a strange problem since I tried to redirect from a folder to a subfolder yesterday.
Have anyone an idea, how can i fix it?
Many thx for your help.
Steffen
I had entered the following in the .htaccess:
# Umschreiben auf www
Options +FollowSymLinks
RewriteEngine an
RewriteCond %{HTTP_HOST} ^subdomain.domain.tld[nc]
RewriteRule ^(.*)$ http://www.subdomain.domain.tld/$1 [r=301,nc]
# 301 Gesamtes Verzeichnis umleiten
RedirectMatch 301 /(.*) /owncloud/$1
This then generated links like this:
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/status.php HTTP/1.0" 200 1820 "-" "Mozilla/5.0 (Windows) mirall/2.10.0 ( build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 (Windows) mirall/2.10. 0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 (Windows) mirall/ 2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 (Windows) mirall/2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/owncloud/owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 ( Windows) mirall/2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
- restart the Plesk Service
- restart the Plesk Server
- clear Cache
- unsuccessful attempts to connect to an owncloud client via different clients (macOs & Windows)
It was then no longer possible to access the owncloud via the browser and the client.
I was able to restore accessibility via the browser. However, accessibility via the client is currently not possible.
the owncloud client should be able to log in.
The following message is issued:
The connection to ownCloud on https://subdomain.domain.tld/dir:
Too many connections could not be established.
Provider : Alfahosting
Operating system : Ubuntu 20.04 LTS, Plesk Obsidian Version 18.0.43
Web server: Apache, Nginx
PHP version: 7.4
ownCloud version: 10.0.1.4
fresh install
about the Browser with the zip image.
<?php
$CONFIG = array(
'instanceid' => '',
'passwordsalt' => 'PASSWORD',
'secret' => '',
'trusted_domains' =>
array(
0 => 'subdomain.domain.tld',
'datadirectory' => '/var/www/vhosts/domain.de\/oc_data',
'overwrite.cli.url' => 'https://subdomain.domain.de/owncloud',
'dbtype' => 'mysql',
'version' => '10.0.10.4',
'dbname' => 'myDatebase',
'dbhost' => 'localhost:3306',
'dbtableprefix' => 'oc_',
'dbuser' => 'myDbUser',
'dbpassword' => myPassword',
'logtimezone' => 'UTC',
'installed' => true,
'loglevel' => 0,
"system": {
"instanceid": "octgld60nt5t",
"trusted_domains": [
"subdomain.domain.tld"
"datadirectory": "\/var\/www\/vhosts\/domain.de\/data_oc",
"overwrite.cli.url": "https:\/\/subdomain.domain.tld",
"dbtype": "mysql",
"version": "10.9.1.2",
"dbname": "",
"dbhost": "localhost:3306",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"theme": "",
"loglevel": 0,
"maintenance": false,
"default_language": "de",
"enable_certificate_management": true,
"mail_smtpmode": "php",
"updater.secret": "***REMOVED SENSITIVE VALUE***",
"enable_previews": false,
"mail_smtpport": "993",
"mail_smtpauthtype": "LOGIN",
"mail_smtpauth": 1,
"mail_smtpsecure": "ssl",
"allow_user_to_change_mail_address": "",
"debug": false,
"defaultapp": "files",
"session_lifetime": 28800,
"remember_login_cookie_lifetime": 28800,
"trashbin_retention_obligation": 7,
"trashbin_skip_size_threshold": "500MB",
"versions_retention_obligation": 14,
"0": 30,
"integrity.excluded.files": [
".DS_Store",
"Thumbs.db",
".directory",
".webapp",
".htaccess",
".user.ini"
no
no
no
isn't configured
Firefox, Safari, Edge, Chrome
Windows 11, macOS 12.3.1
there is no information about this proces
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/status.php HTTP/1.0" 200 1820 "-" "Mozilla/5.0 (Windows) mirall/2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 (Windows) mirall/2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 (Windows) mirall/2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
89.247.163.113 - - [12/May/2022:12:03:14 +0200] "GET /owncloud/owncloud/owncloud/owncloud/owncloud/status.php HTTP/1.0" 404 1607 "-" "Mozilla/5.0 (Windows) mirall/2.10.0 (build 6519) (ownCloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
there is no information about this process (loglevel 0)
