I am getting this error “Your data directory and your files are probably accessible from the Internet. The .htaccess file is not working. We strongly suggest that you configure your web server in a way that the data directory is no longer accessible or you move the data directory outside the web server document root.”
the .htaccess itself seems to be used, if i break it intentionally i get the internal server error message.
I have also enabled mod_rewrite.
Yes, i have done the vhost part as well as the apacha2.conf one.
I believe these settings just ensure that the .htaccess is actually used?
If i break the file intentionally for example by adding .Test on top I will get this
