HTTP Error 500 after upgrade to owncloud 9.1
Following this thread → Upgrading from 9 to 9.1 using occ command gives exception error - #3 by karasardelis
After the upgrade i am unable to use owncloud due to HTTP Error 500
Any help is appreciated
This happened after an update
Owncloud should start normally after an update
HTTP Error 500
Operating system: Linux centos 2.6.32-642.1.1.el6.x86_64 #1 SMP Tue May 31 21:57:07 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Web server: Apache version 2.2.15
Database: MySQL version 5.5.37
PHP version: PHP 5.4.27
Updated from an older ownCloud or fresh install: Updated from 8.x
Special configuration : external storage, external authentication
is missing here. Without logfiles its not possible to help
@RealRancor logfile seems truncated and is filled with message like these:
{“reqId”:“FrrYiwSJUOBWeldXX5rZ”,“remoteAddr”:“”,“app”:“PHP”,“message”:“str_repeat(): Second argument has to be greater than or equal to 0 at /var/www/html/owncloud/3rdparty/symfony/console/Helper/ProgressBar.php#572”,“level”:3,“time”:“2016-09-08T10:09:54+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“FrrYiwSJUOBWeldXX5rZ”,“remoteAddr”:“”,“app”:“user_ldap”,“message”:“initializing paged search for Filter objectClass=* base Array\n(\n [0] => cn=,ou=,ou= unit,ou=users,ou=corporate,dc=,dc=\n)\n attr Array\n(\n [0] => primaryGroupID\n)\n limit 500 offset 0",“level”:0,“time”:“2016-09-08T10:09:54+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“FrrYiwSJUOBWeldXX5rZ”,“remoteAddr”:“”,“app”:“user_ldap”,“message”:“Ready for a paged search”,“level”:0,“time”:“2016-09-08T10:09:54+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“FrrYiwSJUOBWeldXX5rZ”,“remoteAddr”:“”,“app”:“user_ldap”,“message”:"initializing paged search for Filter objectClass=
base Array\n(\n [0] => dc=
*****,dc=
\n)\n attr Array\n(\n [0] => objectsid\n)\n limit 500 offset 0”,“level”:0,“time”:“2016-09-08T10:09:54+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
{“reqId”:“FrrYiwSJUOBWeldXX5rZ”,“remoteAddr”:“”,“app”:“user_ldap”,“message”:“initializing paged search for Filter (&(&(|(objectclass=group)))(objectsid=S-1-5-21-1993632213-335689477-1777090905-513)) base Array\n(\n [0] => OU=,OU=Other,OU=User Groups,OU=,DC=**,DC=\n)\n attr Array\n(\n [0] => dn\n)\n limit 1 offset 0”,“level”:0,“time”:“2016-09-08T10:09:54+00:00”,“method”:“–”,“url”:“–”,“user”:“–”}
Total log file is over 500Mb in size and is quite difficult to upload… :frowning:
Apache error_log revealed the solution to my problem…
[Thu Sep 08 16:49:04 2016] [error] [client 10.1.5.200] PHP Warning: fopen(/var/www/html/owncloud/config/config.php): failed to open stream: Permission denied in /var/www/html/owncloud/lib/private/Config.php on line 187
[Thu Sep 08 16:49:04 2016] [error] [client 10.1.5.200] PHP Warning: flock() expects parameter 1 to be resource, boolean given in /var/www/html/owncloud/lib/private/Config.php on line 197
[Thu Sep 08 16:49:04 2016] [error] [client 10.1.5.200] PHP Fatal error: Call to a member function getLogger() on a non-object in /var/www/html/owncloud/index.php on line 51
config.php wasn’t writable anymore, so i changed the permissions and problem solved! Thanks…
