bonne
July 25, 2016, 10:01pm
1
Default OwnCloud 9.1 install on minimal Centos 7.
Getting:
[Mon Jul 25 23:56:10.194357 2016] [:error] [pid 2268] [client xxx:53739] PHP Fatal error: Class 'Memcached' not found in /var/www/html/owncloud/config/config.php on line 954
memcache.so exists and loaded in php.ini
ps ax | grep memcached
866 ? Ssl 0:00 /usr/bin/memcached -u memcached -p 11211 -m 64 -c 1024
Where to go?
Regards, Lars.
quoting from the documentation:
Be sure to install the memcached PHP module, and not memcache, as in the following examples. ownCloud supports only the memcached PHP module.
https://doc.owncloud.org/server/9.1/admin_manual/configuration_server/caching_configuration.html#id3
Also consider using APCu instead of memcached as recommended here:
https://doc.owncloud.org/server/9.1/admin_manual/configuration_server/caching_configuration.html#recommendations-based-on-type-of-deployment
