HTTP methods MKCOL and DELETE return error 501 Not Implemented
Hello everyone,
I have installed my ownCloud server (10.0.2) on a shared web hosting service. Some features, like creating a folder or deleting a sharing, are not working.
In both cases, the HTTP request returns an error “501 Not Implemented : The requested method is not implemented by the server.”
It’s as if there was a reverse proxy blocking HTTP methods like MKCOL and DELETE, but I don’t think there’s one installed.
I’d be grateful to receive some help, unfortunately I’m totally lost…
  1. Log as admin on my ownCloud web interface
  2. Try to create a new folder / try to delete a sharing
The folder is created, the sharing is deleted.
The folder is not created, the sharing is not deleted.
My ownCloud server is installed on a shared web hosting service.
Apache2
10.1.24-MariaDB
10.0.2
ownCloud 9.1.4 first installed then upgraded to owncloud 10.0.0, then to 10.0.2
Softaculous apps installer
No
No
No
Contact your provider about this or use a real vserver. :slight_smile:
Thank you much for your advice @guruz ! :slight_smile:
In case that would be helpful to someone else, the solution was given to me [here] (ownCloud - hébergement mutualisé : requêtes HTTP DELETE et MKCOL bloquées - PlanetHoster | PlanetHoster Forums).
It’s in french, so here’s the trick:
I had to add the following lines in the .htaccess file at the root of my ownCloud directory:
<IfModule mod_security2.c>
SecRuleRemoveById 1234123435
</IfModule>
The explanation might be found in this over post.
