Hi Guys,
For the life of me, I cannot get HTTPS reverse proxy working.
I installed the official Docker image of ownCloud on my Unraid server.
I made a DB with the docker image MariaDB. All that works fine. ownCloud opens at my local IP 192.168.0.10:8000.
Now here’s the real issue. I created my reverse proxy using the Docker image NGINX Proxy Manager.
I have Heimdal working perfectly with NGINX Proxy Manager. ownCloud work perfectly ONLY WITH HTTP! This is clearly an issue since I plan on having ownCloud available from external network.
Anytime I try to set the reverse proxy to HTTPS, I get an error around the line of “can’t process the request” or “page unavailable” (I can confirm the error once I’m back home from work)
I have tried to add ovewriteprotocol => https and overwriteurl(or wtv, I can’t remember off the top) => my.domain.com
I’m running out of ideas to what the issue could be. I am reinstalling Unraid and redoing the whole setup (MariaDB, ownCloud and NGINX Proxy Manager) in hopes of fixing the issue.
Am I missing anything or doing anything wrong??
