I have the Hyper-V applience running. About 2 weeks ago, the VM suffered disk corruption and was not accessable. As i was only testing, I replaced the vhd with the oritinal and restarted teh applience and set it up again.
Today I have the same problem.
On the console it says:-
[826252.833336] end_requesr: I/O error, dev sda, sector 1069880
[826252.911154] Aborting journal on device sda-8.
[826252.937058] EXT4-fs error (device sda1): ext4-journal_check_start:56: Detected aborted journal
[826252.938553] EXT4-fs (sda1): remounting filesystem read-only
If I reboot the VM, during boot i get:-
EXT4-fs (sda1): Couldnt remount RDWR because of unprocessed orphan inode list. Please unmount/remount instead
An error occured while mounting /.
Press S to skip mounting or M for manual recovery
Anyidea what is going wrong? I have about 15 other machines running on this host with a mixture of Win and CentOS and none of those are complaining so i am assuming its not a host storage issue.
ian..
