<?php
* @author Jörn Friedrich Dreyer
* @author Lukas Reschke
* @author Morris Jobke
* @author Philipp Schaffrath
* @author RealRancor
* @author Robin Appelman
* @author Sergio BertolÃn
* @author Thomas Müller
* @author Vincent Petry
* @copyright Copyright (c) 2018, ownCloud GmbH
* @license AGPL-3.0
* This code is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License, version 3,
* along with this program. If not, see
// Show warning if a PHP version below 7.3.0 is used, this has to happen here
// because base.php will already use 7.3 syntax.
if (\version_compare(PHP_VERSION, '7.3.0') === -1) {
echo 'This version of ownCloud requires at least PHP 7.3.0
echo 'You are currently running PHP ' . PHP_VERSION . '. Please update your PHP version.';
return;
// Show warning if PHP 8.0 or later is used as ownCloud is not compatible with PHP 8.0
if (\version_compare(PHP_VERSION, '8.0.0') !== -1) {
echo 'This version of ownCloud is not compatible with PHP 8.0
echo 'You are currently running PHP ' . PHP_VERSION . '.';
return;
// running oC on Windows is unsupported since 8.1, this has to happen here because
// is seems that the autoloader on Windows fails later and just throws an exception.
if (\stripos(PHP_OS, 'WIN') === 0) {
echo 'ownCloud Server does not support Microsoft Windows.';
return;
try {
require_once __DIR__ . '/lib/base.php';
OC::handleRequest();
} catch (\OC\ServiceUnavailableException $ex) {
\OC::$server->getLogger()->logException($ex, ['app' => 'index']);
//show the user a detailed error page
OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE);
OC_Template::printExceptionErrorPage($ex);
} catch (\OC\HintException $ex) {
OC_Template::printErrorPage($ex->getMessage(), $ex->getHint());
} catch (\OC\User\LoginException $ex) {
OC_Response::setStatus(OC_Response::STATUS_FORBIDDEN);
OC_Template::printErrorPage($ex->getMessage());
} catch (\OCP\Files\ForbiddenException $ex) {
} catch (\Throwable $ex) {
try {
OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR);
} catch (\Throwable $ex2) {
// with some env issues, it can happen that the logger couldn't log properly,
// so print out the exception directly
// NOTE: If we've reached this point, something has gone really wrong because
// we couldn't even get the logger, so don't rely on ownCloud here.
\header("{$_SERVER['SERVER_PROTOCOL']} 599 Broken");
\OC::crashLog($ex);
\OC::crashLog($ex2);
Maybe a misunderstanding?
