I have a 503 error
first of all, i’m learning english, so sorry if you find some error :slight_smile:
I write you today because since some days, I have a problem with my owncloud server… When I go to my Home page: http://fabian-cloud.ddns.net, everythings is normal but when I go to the Owncloud application or http://fabian-cloud.ddns.net/owncloud, I have an error:
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.4.10 (Univention) Server at fabian-cloud.ddns.net Port 80
I don’t know how it’s possible because I didn’t change anythings… And because I’m not strong, I don’t know what to do :cry:
That’s why I come to you today :slight_smile:
Who can help me?
In order to help you information about your setup is needed, please fill this out as much as possible:
thanks for answer.
1)Expected behaviour
When i go to http://fabian-cloud.ddns.net/owncloud/, icould go on the usually owncloud webpage
2) Actual behaviour
i have this error message: 503 service unavaible
Service Unavailable
3)Server configuration
3.1)Debian 64bit
3.2)Apache
3.3)Unknown (I don’t know what it is but I can say that I use UCS System. In did, I downloaded the Applicance with virtual box to the official website)
3.4)Unknown but it should be a recent version because I only had install Owncloud for 3 months
3.5)10.0.3
3.6)Like I said earlier, It’s a recent install ( at about 3 months)
3.7)from the official website: Download Server Packages - ownCloud I downloaded the appliance with VirtualBox
3.8)Can you tell me more explication? I login as admin in my shell and what should I do?
3.9)When I put config/config.php, it says that there is no file or folder with this name
3.10)When I put the “sudo -u www-data php occ app:list” command, it says that it could not open input file: occ
3.11)no I don’t use an external stockage but i use VirtualBox
3.12) I don’t think I’m using encryption (i didn’t do something like that)
3.13) Like top, I don’t beleave. I just installed my owncloud and didn’t do anything after
4)Client configuration
4.1)Google Chrome
4.2) Windows 7 and my phone (android 6.0)
I found somethings new: when I go to graphic admin page and that I go to the System software, I have a pop up where it says:
Update notes
The update is being executed.
Leave the system up and running at any moment during the update!
It is expected that the system may not respond (via web browser, SSH, etc.) during a period of up to several minutes during the update as services are stopped, updated, and restarted.
But it strange because it will be at about 1 week i have this problem and that my computer turn 24/24h 7/7days
EDIT: ok I really think that the problem is that: It says that its doing an update but like I said, It will be at about 1 week I have this problem. Do you know how to resolve that?
It would be helpful to get the log files from your server.
You have to connect to your server, then execute this command:
univention-app shell owncloud
That get’s you in the owncloud docker container.
Then you can do a “cat” on the log file
cat /var/lib/univention-appcenter/apps/owncloud/data/files/owncloud.log
There you can look for the reason of your problems.
first, thanks to take time for me :slight_smile:
secondly, when I put the first command, I have an error:
after when I put the second command like this:
My shell shows a lot of things and it never stops:
What can I do?
EDIT: I puted sudo before the first command and the error disepeard!!!
But There is always the same thing for the second command…
Can you download the log file and upload it somewhere?
You want that I copy all what it says in the shell?
But how can I do that? I’m using Debian without Graphic Interface, so I don’t really know how to copy that…
Can we speak in private? I could give you remote access if you have time and mostly, if you want!
Ok I think I know what’s the problem!
I checked the log file and I found a lot of line where it says “no space left” so I checked the size on my VirtualBox settings and in did, the disk has 46,5/50 GB used. So now, I’m looking for increase the size of the disk. I’ll tell you if it was that :slight_smile:
can you increase the size?
