I want to acess New created Mount point on Vm of Owncloud through UI
Operating system: Ubuntu 18.04
Web server: Apache2
**Database:**Mysql
ownCloud version: (see ownCloud admin page) : - 10.3.2.2
Where did you install ownCloud from: I have refered This Link : - https://www.fosslinux.com/8797/how-to-install-and-configure-owncloud-on-ubuntu-18-04-lts.htm
this seems to be an empty post except for the template.
If you’re mounting a filesystem you have to make sure the webserver user can read and write to it. For that you will have to login to the system before you will be able to add it in the ownCloud UI.
@eneubauerYes, webserver user can read and write.
So what is the problem then? Why are you not able to add it? Perhaps add some more information to the initial post with the template: how would I be able to reproduce the issue?
Its Done now, Working finally with it…
