IfModule Mod_rewrite - settings in .htaccess file not retained during upgrade
Hello, Every time I upgrade I have to re-enter the IfModule Mod_rewrite settings in my .htaccess file. I’m sure this is a miconfiguration I have somewhere but not sure where. Any ideas? See info below.
thanks!
  1. Occurs After each Upgrade
.htaccess file should retain info
.htaccess file does not retain info and has to be added back into .htaccess file after upgrade
Ubuntu 16.04
Apache
Mysql
PHP 7.0.22
10.0.5
Update
Package installation
<?php $CONFIG = array ( 'updatechecker' => false, 'instanceid' => 'xxx', 'passwordsalt' => 'xxx', 'secret' => 'xxx', 'trusted_domains' => array ( 0 => 'xxx', 1 => 'xxx', 2 => 'xxx', ), 'datadirectory' => '/var/www/owncloud/data', 'overwrite.cli.url' => 'https://xxx.net', 'dbtype' => 'mysql', 'version' => '10.0.4.4', 'dbname' => 'xxx', 'dbhost' => 'localhost:3306', 'dbtableprefix' => 'oc_', 'mysql.utf8mb4' => true, 'dbuser' => 'xxx', 'dbpassword' => 'xxx', 'logtimezone' => 'UTC', 'installed' => true, 'mail_smtpmode' => 'smtp', 'mail_smtpsecure' => 'ssl', 'mail_from_address' => 'owncloud', 'mail_domain' => 'xxx', 'mail_smtpauthtype' => 'LOGIN', 'mail_smtpauth' => 1, 'mail_smtphost' => 'xxx', 'mail_smtpport' => '465', 'mail_smtpname' => 'xxx', 'mail_smtppassword' => 'xxx', 'files_external_allow_create_new_local' => 'true', 'maintenance' => false, 'loglevel' => 0, 'memcache.local' => '\\OC\\Memcache\\Redis', 'filelocking.enabled' => 'true', 'memcache.distributed' => '\\OC\\Memcache\\Redis', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => 'localhost', 'port' => 6379, 'timeout' => 0, 'dbindex' => 0, ), 'theme' => '', ); **List of activated apps:** ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** local/smb/sftp/... Yes, Local **Are you using encryption:** yes/no No. **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... #### LDAP configuration (delete this part if not used) ``` With access to your command line run e.g.: sudo -u www-data php occ ldap:show-config from within your ownCloud installation folder Without access to your command line download the data/owncloud.db to your local computer or access your SQL server remotely and run the select query: SELECT * FROM `oc_appconfig` WHERE `appid` = 'user_ldap'; Eventually replace sensitive data as the name/IP-address of your LDAP server or groups. ``` ### Client configuration **Browser:** **Operating system:** ### Logs #### Web server error log ``` Insert your webserver log here ``` #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ``` #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
You can enable this module with a command like this, witthout writing it in the .htaccess file
a2enmod “module” enable
