Does OwnCloud (server) block iframe url links?
I’m trying to embed my owncloud login link but it keeps showing up as white.
If so, is there a way around this? Thank you
Would really appreciate some input here. thanks
Have you checked your browser console? Issues regarding the content security policy and others should show up there. The described behavior sounds like CSP: frame-ancestors - HTTP | MDN. If so, you can overwrite the CSP within your reverse proxy/webserver vhost config.
See core/response.php at master · owncloud/core · GitHub as the default policy is set to self, this might block embedding your instance as an iframe somewhere else.
