Im Ablauf des SSL-Protokolls ist ein Fehler aufgetreten
I cannot syncronise my data using owncloud client. The following error occurs:
does someone know this error ?
no error expected
Client version: 3.0.0.9215
Operating system: Ubuntu 22.04
in english:
Server replied with an error while reading directory ‘xxx/xxx/xxx’ : SSL handshake failed
This could mean anything: an incorrect/outdated server configuration, a local Qt issue, … We need more information. Please tell us how you installed the client. Also, a log file might reveal more detailed information, so please provide one.
You may have to enable logging in the settings first, though, or provide the according CLI parameters. See Command Line Options :: ownCloud Documentation for more information.
Hello Thank you for your reply.
Here is the log file I found in the owncloud folder. Does that help ?
.owncloudsync.log (360.5 KB)
No. Please delete it, it is publicly accessible and contains personal data.
You need to enable logging in the settings, as mentioned in my previous post. Open the client settings, go to “Log settings” and enable logging to a temporary directory. The user interface will tell you the exact path.
here is the log file following your advise:
ownCloud.log (104.9 KB)
