After upgrading from 10.0.3 to 10.0.4 (10.0.4.4) logging in with the OC_User_IMAP- Backed does not work any more.
When enabling the following in the config.php:
"'user_backends' => array(
array(
'class' => 'OC_User_IMAP',
'arguments' => array('{imap.example.com:993/imap/ssl}')
the login does not work any more. After entering the credentials the following error-message occurs:
Zugriff verboten
CSRF check failed
That also occurs when trying to login with the admin-user.
When disabling the statement, the login with the admin-user works again.
The login via Owncloud-Client-Applikation does work though.
See above
Login should work with imap
Operating system: OpenSuse
Web server: Apache2
Database: MariaDB
PHP version: 7.0
ownCloud version: (see ownCloud admin page) 4.0.4.4
Updated from an older ownCloud or fresh install: 3.0.3
Where did you install ownCloud from: tried both, admin cosole in web-view and via zip-package on console
Signing status (ownCloud 9.0 and above): ok
<?php
$CONFIG = array (
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
'trusted_domains' =>
array (
0 => 'cloud.****.org',
'datadirectory' => '/home/owncloud',
'overwrite.cli.url' => 'https://cloud.***.org',
'dbtype' => 'mysql',
'version' => '10.0.4.4',
'dbname' => 'cloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => 'cloud',
'dbpassword' => '***',
'logtimezone' => 'UTC',
'installed' => true,
'mail_from_address' => 'cloud',
'mail_smtpmode' => 'php',
'mail_domain' => '***.org',
'csrf.disabled' => false,
array(
'arguments' => array('{imap.***.com:993/imap/ssl}')
**List of activated apps:**
from within your ownCloud installation folder.`
**Are you using external storage, if yes which one:no
Are you using encryption: no
Are you using an external user-backend, if yes which one: IMAP!
Browser: Opera
Operating system: Windows 10
