Hi
Since the autoupdater function has been giving me problems for weeks,
I decided to try a manual upgrade as suggested by another user.
Despite having switched to PHP 5.6.31 as required,
The update command returns this error.
/var/www/vhosts/httpdocs$ sudo -u apache php occ upgrade
No entry for terminal type "unknown";
using dumb terminal settings.
This version of ownCloud requires at least PHP 5.6.0
You are currently running 5.4.16. Please update your PHP version.
I'm trying to upgrade from 9.1.5 to 10.0.3 on Cent OS
Suggestions?
